Door Speakers
I'm in need of two new door speakers, I found stock ones in an ecklers magazine but as I recall they were $80 a piece. I've tried calling junk yards in the area but there aren't any f-bodies in any of them. I really don't want to spend $160 on speakers as I'm in need of a new exhaust system and battery. Any ideas?
Well unless you have the bose/infinity system, just about any 6.5" speaker will work. You could get some cheapie wal-mart ones to work until you can get some better ones. Or go looking through the junk yards at other GM cars and you should find some that'll work.
In my C4 Vette, each Bose speaker has it's own amp. Isn't the Camaro the same way? If so, don't expect off the shelf speakers to work above a whisper with the Bose stereo.
And often times, when those speakers go out, it's the amp not the speaker that's the problem.
If you have a stock stereo emitting sound out of your bose system, then replacing the stock speakers with aftermarket 6.5 will work fine, as long ans you mount it to the speaker amp housing and plug it in.
Now if you want to do an aftermarket radio, you can run new wires, or get a output converter. Reason being, some grounds are shared to the amp from the harness, this will make an after market work with your harness. This one comes with directions for our bose systems and is easy to install.
AAMP OF AMERICA, INC 011 - PERIPHERALPREMIUM OUTPUT CONVERTER - ISVE61
