Door lock issues
I searched and couldnt find anything specific to my issue.
95 camaro z28
Basically the car doors continue to unlock themselves. While driving while sitting while running while off.
Any suggestions.
Also my interior light fuse kept blowing until I unplugged my after market amp. Since then the interior fuse no longer blows but I am more concerned out the doors continuing to unlock themselves.
95 camaro z28
Any suggestions.
I'm assuming tht that your car has Remote Keyless Entry (RKE). True? Even if you don't have a keyfob remote the car may have it. Check the glove box door label for code AU0. If it's there, the car has RKE.
The control module for that system is located behind the RH kick panel. Every 93/94/95 that I've looked at in the junkyard with that RKE system has water damage to the module. Don't know how the water gets down there but the connector is on top of the module and the water follows wiring right to the module connector.
There's probably water in yours shorting out something.
