Door Hinges
Hey All,
Does anyone know of a place that sells the lower door hinge for the driver and passenger side? I can find only the passenger side and the local Chevy dealer says the driver side is discontinued. It is for a 2002. Thanks!! |
Originally Posted by sunfire
(Post 417875)
Hey All,
It is the whole hinge. I wasn't able to find the part online either.
(Post 417917)
Actually that may not work, that almost looks like a pre-70's hinge. Have you tried looking at GMPartsDirect.com? |
check your local junkyards too. that kind of obscure stuff is usually pretty easy to find because it isn't in high demand.
You're right luciora, that is a pre-70's hinge on ebay. I did find the part at gmdirectpart.com though, so thanks for the idea.
(Post 418117)
Bad news. When I tried to order the left side lower hinge from gmpartsdirect.com, it says that it is no longer available. Any ideas you guys have would be appreciated.
try eklers, oem parts for less, rms auto, usa autoparts
| All times are GMT -5. The time now is 08:37 AM. |
