Dip stick oil level
Just noticed that my oil dip stick is about almost half a inch above the grated area where your oil level is supposed to be. Is this too much, will it cause the foam oil problem?
Forgot to mention its a 1998 z28 ls1
Just doing some research on the internet and thought I would add that the engine was not at running temp when I checked this. It had been sitting for a hour and it was pretty cold outside.
I will check again tommorow after the engine is heated up. |
woh,,, do you always talk to yourself? lol. yep and you gave good advice to. check oil after shutting it off and see what it reads.
^ ...But not right after shutting it off, as oil will still be clinging to internal parts. Let it settle for a couple of minutes.
| All times are GMT -5. The time now is 08:06 AM. |
