Did the guy I bought the car from change out the gears?
Old 12-07-2010, 11:41 AM
1augapfel's Avatar
Here's an online calculator to determine road speed (or RPMs) for a given set of parameters that include final drive gearing, transmission final drive ratio, and tire diameter.
http://www.bgsoflex.com/rpmmph.html
On your automatic you should assume that you're in overdrive at highway speeds and there's negligible slip in the lockup converter. That means the transmission final drive ratio is 0.696 : 1 (for every 0.7 turns of the engine crankshaft the transmission output shaft and driveshaft rotates one full turn).
You'll have to measure your car's tire diameter.
LHill00Z28
10-03-2009 12:36 AM
welch7122
07-29-2009 07:16 AM
spisak
07-30-2008 09:16 PM
00camaross
LS Series Tech
10-18-2006 10:47 AM
Quick Reply: Did the guy I bought the car from change out the gears?
