Dex-cool
Old 12-28-2014, 11:34 AM
bbjk08's Avatar
Default Dex-cool
Just wondering what you guys think about the DEX-COOL antifreeze and wondering if I should switch to a different kind or not.
From what I've read, under perfect conditions (no leaks or other problems), it works great and lasts 5 years/150,000 miles, but if you ever do have a leak, it can turn acidic and eat up seals/gaskets and cause major problems if air gets into the system.
My car is 20 years old now (1995 3.4L), so I don't want to assume perfect conditions because things wear out on it all the time. I switched over to DEX-COOL in December 2011 after I got another engine due to a blown head gasket. When I picked up the car from the shop, it had DEX-COOL in it, so I just let it be.
Now I think some of my hoses are old and have slow leaks. I have to add a little coolant once or twice every few weeks or so.
SO, should I just replace the bad hoses and get on with my life, or should I switch to a different kind of antifreeze? I've heard good things about yellow antifreeze. What do you guys think?
ALSO, I know you can't just mix different kinds of antifreeze. Would a regular coolant system flush be good enough to clean out the system before switching to a different kind? What is the correct procedure to switch to a different kind?
Old 12-28-2014, 02:17 PM
GaryDoug's Avatar
I have used Dex-Cool in my Trans Am since I bought it new in 98. 100k miles now. I have replaced the water pump once and the system went almost dry at that time. No issues with the coolant ever. I do hear of more complaints from V6/3.8L owners, probably because of the wet intake manifold design. By the way Dex-Cool is made by several companies. It is a GM spec/standard, not just a product name.
Old 12-28-2014, 07:03 PM
MKCoconuts's Avatar
The only problem with Dex-Cool (and any OAT and HOAT antifreeze/coolant for that matter) is that when it's not properly maintained, it becomes acidic and turns into a brown gunk that can and will eventually plug coolant passages and eat seals/gaskets. When it's maintained as recommended, it is fine.
Personally, I run the standard old green ethylene glycol for the simple fact that it's cheap and it is available every where. Though Dex-Cool isn't that hard to find either, just costs a few bucks more.
Old 12-29-2014, 03:22 PM
torque_is_good's Avatar
I'm with MK
Peak or Walmart brand and I don't buy the pre-mix. Why pay $1 less for 1/2 gallon of water?
I flush every 2 years or 30k miles in all of my cars
Old 12-29-2014, 09:40 PM
flush it out if your changing to the green stuff. do not want to mix the two different kinds. turns to jello. i have always used the green stuff. probably should have changed your head gaskets before installing the newer engine.
mpkoester
02-05-2010 10:22 AM
purpl96
03-07-2008 09:28 AM
Quick Reply: Dex-cool
