from delco 4 speakers to Monsoon 8 !
Old Mar 11, 2012 | 05:07 AM
androzer's Avatar
Default from delco 4 speakers to Monsoon 8 !
hi guys I have 1994 camaro my after market 1 din radio has ben stolen and the trim has been smashed, I found that there is available monsoon Pontiac 8 speaker cassette player, do I need to have amplifier to install it?
here are mu connections 1995 Chevrolet Camaro Stereo Wiring Information
and I have in front 2 kenowod speakers and back 2 original speakers.
and any one have any idea what to put? do u think it's nice to put 2 din?
Old Mar 11, 2012 | 12:39 PM
Failed Devices's Avatar
The Monsoon head units did use an amplifier; also the Monsoon system is a 1.5 DIN.
This shouyld help you out on any questions you might have on the Monsoon units:
http://ls1tech.com/forums/stereo-ele...nsoon-faq.html
Old Mar 11, 2012 | 06:40 PM
androzer's Avatar
my point is that I don't have amplifier available. only the head unit.
Old Mar 15, 2012 | 01:30 PM
androzer's Avatar
GUYS, my point is can some one use Delco Bose or Monsoon on normal speakers?
Old Mar 15, 2012 | 02:33 PM
Shouldn't matter what the head unit is for the speakers. Either a Camaro or TA HU will fit, aftermarket HU will just require an adapter for the plugin
Old Mar 15, 2012 | 03:25 PM
Mikey.'s Avatar
I don't think that just the head unit has enough power to run all of the speakers on it's own, or at all. You could always run an aftermarket amp.
Old Mar 15, 2012 | 03:59 PM
If his car did not come with the Monsoon system, then he has a 4 speaker setup which is always run from just the HU. Cars with the Monsoon system had the 8/10 speaker setups and used an external amp.
Old Mar 15, 2012 | 04:10 PM
Mikey.'s Avatar
Ah. I read it wrong, I thought he was trying to swap the speakers too.
Old Mar 15, 2012 | 04:27 PM
Spatfieya's Avatar
I dunno, I think the outputs might be different from regular stock HU because of the amp setup.. I.E. How bose amps have shared grounds n stuff..
Old Mar 15, 2012 | 05:56 PM
As far as I know, the Monsoon name was just that, a name. When you upgraded to the Monsoon system, the HU remained the same as all additional speakers were powered by the amp.
