dash pad
i am pissed i went today to clean the car wipeing the dash pad off and it cracks into little bits what the hell well wondering where can i get one and how hard to replace
its about $350 to get one new from a website only. but the cheaper way is to get the dash mat. it covers the dash pad and looks fairly stock. those are between $60-$100 depending on where you get it. to get the dash pad go to www.newgmparts.com enter your car info and then scroll down to insterment panel click and go into insterment panel again and the part you want is the crash pad.
for the dash mat go to www.rksport.com select your car info got to interior styling and select the dashmat you want. If you go the new dash pad route to remove your old one just lift it up. its held down by clips in the front and velcro pads on the side against the windsheild. you'll also have to remove the tower covers and by doing that push the upper portion out of the car and the lower portion into the car. hope that helps. |
130 ebay
new gm dash pad can be had on ebabe for 264.95
classic has em for 325. http://www.classicindustries.com/cam...rts/g4322.html |
