Cranks, wont start but smoke out of exhaust
Old 09-13-2008 | 11:59 AM
HighRisk's Avatar
Default Cranks, wont start but smoke out of exhaust
Ok so I just bought a 95 lt1 6 speed Camaro last week and drove it home and everything was fine. I parked the car last sunday and I went to go start it today and it will turn over but it wont start. The thing that freaks me out is that smoke is coming out of the exhaust, looks like the smoke that would come from a fire after you put it out. I've started the car a couple times after I got it and the most recent being yesterday which it ran fine. Although the engine light was on when the car was on but it would shut off when you started it. Anyway today after it didn't start I figured it might be the fuel pump, so I had the hood open and I turned the key on but didn't start it and I could hear the fuel pump prime but there was this whistling sound from the engine bay, probably the fuel rail but I don't know if thats normal. Anyway if anyone has any explanation to whats going on it would be greatly appreciated, I am about to kill myself I'm having an awful day. Thanks
Old 09-13-2008 | 01:29 PM
Nessy's Avatar
Default RE: Cranks, wont start but smoke out of exhaust
If it is not the fuel pump then I would check the fuel injection sytem. If theres nothing you can do to determine/fix it, try running some codes and see if anything comes up.
Old 09-13-2008 | 01:40 PM
02StanGT's Avatar
What color smoke? Bluish = oil dark gray/ black = too much unburned fuel white = coolant
Old 09-13-2008 | 11:11 PM
HighRisk's Avatar
I went out earlier today after I made the post and it started. It took a little longer than usual but it started and then I let it run for a little bit and took it up the road and it ran fine. I don't know whats going on but I think I'll take it into the Chevy dealer and run the codes on it thx guys.
Old 09-28-2008 | 10:51 AM
whitelt1's Avatar
I had the same problem. Check the distributer.
Taintedlogic
10-16-2013 05:11 AM
onebad88
09-01-2012 10:36 PM
burning camaro
10-30-2010 11:41 AM
1971RS
01-05-2009 12:06 AM
92ChevyCamOwner
03-04-2006 03:32 PM
Quick Reply: Cranks, wont start but smoke out of exhaust
