cooling fans always on?
i never thought of this as odd but it seems like whenever my car is idling both fans are on, and its well, kinda loud
is this supposed to happen?
its not exactly loud it just sounds liek i have the A/C on full blast from outside the car and i actually dont even have it engaged at all
Depends on what the temp of the engine is. There is no air circulation through the radiator when the car is idling and that usually increases the coolant temp enough for the sensors to tell the computer to energize the fans.
The fans should be off on a cold engine. If they are on with a cold engine and AC off, look for modified wiring, bad relay (welded contacts), short to ground on control leads from PCM, or messed up PCM.
a bad temp sensor would do it. test the sensor to see if its saying the car is hot.
http://shbox.com/1/4th_gen_tech2.html#ect
got it all taken car of, just a bad ground (i think?) just took off all wires and put them back on it doesnt do it anymore
my car never runs hot btw, always very cool even with it being upwards of 105 degrees here lately
