coolant leak!!!
Old Mar 18, 2012 | 09:29 PM
Old Apr 23, 2012 | 10:52 PM
Royce Bayles's Avatar
Hi im new here i had to pull my tensioner ***. today and the metal end broke off in the block !!! any suggestions on how to remove the part still in the block ?
ImageShack® - Online Photo and Video Hosting
Update!!
ok i got the piece out of the block by using a dremel tool with the cutting wheel. Tip the cutting wheel is almost as big as the housing so grind it down a bit on concrete or a junk peice of iron if not be carefull not to cut into the housing or you will have to fill the cut before installing anything. Make a cut not too deep but deep enough to stick a flat head screwdriver tip in it and pry it til it breaks off repeat until you get it out or get to the o-ring once you remove a piece of the o-ring it comes out easily !
http://imageshack.us/photo/my-images...835126582.jpg/
Im about to head to the junkyard and see if my pump assembly will interchange with a lesabre grand am assembly which uses plastic elbows on both ends !!
derrickdiggler
Nov 15, 2011 09:09 PM
mccoyj91
Mar 10, 2010 08:35 PM
VTXed
Nov 25, 2006 12:04 AM
terelk
May 31, 2006 04:18 PM
akohnz
May 22, 2006 06:58 PM
