check engine lite is on???
Old 04-12-2008, 10:13 PM
88ranger's Avatar
Default check engine lite is on???
i have a 96 z28 with the lt1...I got new exaust on my car and had all the cataytic converters takin off, will the make my check engine light come on? I also am havine porblems with my injectors, right were the plug goes in on the injectors the wire coating is melting and i dont know why it is can anyone tell me....i also had a 93 fire bird with a lt1 that was doing the same thing.
Old 04-12-2008, 10:21 PM
Default RE: check engine lite is on???
For one thing the car is complaining that the cats are missing. You have an OBDII computer and it wants to see all four O2 sensors.
Old 04-13-2008, 04:27 PM
88ranger's Avatar
Well when i took the catalytic converters off i kept all four o2 sensors on the car. have you heard of the injector plug in wires melting away?
Old 04-13-2008, 06:42 PM
bidicamaro's Avatar
If you take off the cat's, even if you leave in the O2's, it will leen your engine out (less fuel) because the O2's behind the cat are reading there is to much fuel. When you leenout the engine you also heat up the engine thus maybe the reason you're wires are melting. You may be able toget a set of MIL elimiators for your carbut not sure who sells them anymore. You can also do it better than that by taking it to ashop that'll tuneyour computer for it.
Old 04-13-2008, 08:19 PM
02StanGT's Avatar
ORIGINAL: bidicamaro
The O2 sensors behind the cat monitor it's performance only. They don't adjust fuel trims. That's what the front two O2 sensors are for.
Old 04-13-2008, 08:42 PM
88ranger's Avatar
I saw the wire issue before the cats were removed, and i also had a 93 trans am with an lt1 that was doing the same thing with the injector
plugins having the wire coating melting. I talked to a guy at a chevy dealership and he said if there is a draw some were or if the injector is
not getting the right amount of om's that it could cause the wire to get hot and melt.....does that sound right to you? I was wondering if
anyone that has had the lt1 motors if they have had problems with the wiring harness that is up by the valve covers and intake manifold
getting really dried out and britel because of the heat and if anyone knows any way of treating this problem.
Old 04-14-2008, 10:36 AM
bidicamaro's Avatar
ORIGINAL: 02StanGT
Then what's the explination for removing cat's and it throwing a code? My guess is the code will say that theBank1 sensor2 low voltage. Elaborate a little would you?
richard.nelson100
11-17-2011 03:47 PM
parc0r
04-16-2010 11:55 AM
Chevykicksbut
10-28-2009 07:14 AM
woodysresort
06-01-2009 07:12 AM
Quick Reply: check engine lite is on???
