Check Engine light came on
I hooked up a scanner and these are the codes;
P0113 -air intake temperature sensor circuit high input P0704 - clutch switch input circuit P1111 - intake air temperature circuit intermittent high voltage P1153 Heater oxygen sensor circuit insufficient activity Bank 2 Sensor 1 Is anyone familiar with the above? I can take it in to my shop but If I can correct the above and have the check light turned off, without spending needless money - that would be great. Thanks in advance. Johnny |
check wiring harness for the sensors for any damage. sounds like a sort. if I remember right intake air temp sensor is 5/low volt so if its shorting to 12 volt it would cause a couple of these.
Originally Posted by craby
(Post 746672)
(Post 746672)
You really want to sort this out even if you have to take it to a tech. If the system is seeing high voltage this could be causing a high draw of power and that can fry the quad drivers in the PCM. Meaning new PCM time. As long as you do not get no voltage error your PCM is probably working. |
