Changing fuel pump
Recently figured out my fuel pump was bad. I decided to go with the "hatch" method. I bought the pump, and cut the hole. I'm not to sure of how well the pump will work.. I bought the spectra premium pump with sending unit.
1993-1995 Chevrolet Camaro Fuel Pump - Spectra SP3907H - In-Tank, Quad, OE replacement any thoughts? |
Spectra makes good stuff. You should be fine.
My 94 has almost 140k miles and AFAIK the pump is original. Can't be long now..... |
It'll do the job. No worries!
Thanks for the replies !
My Pump will be arriving tomorrow, hopefully not too late so I can get my baby running again! :D @1aug Mine has about 144k miles, pump was still original up until a few months ago when it pooped out on me; |
Originally Posted by Camaroforlife
(Post 660394)
Originally Posted by Greg08
(Post 660424)
Whered u get the sheetmetal?
Excited to go home & change the pump!! :D
How did you get the pump out? I have to change my pump and cut the access hole, removed the nuts holding the pump on, but can't get the pump out... do you need to remove the lines on top of the pump and tilt the pump to get it out? If so, how do you get the lines removed on top of the tank?
Remove the lines from the pump and it should pull out
| All times are GMT -5. The time now is 05:51 AM. |
