Cats and emissions
Technically all inspections start with a visual inspection, if you don't pass that you don't get to test. You should always be running premium fuel in your Z, that way your computer won't have to retard the timing to eliminate knock.
Premium is friggin expensive tho!!!!! lol.
I wasjust thinking of thigns i could do for like the day to make my car pass emissions... you guys seriously run premiumregularly tho?
Hey 95, do you have a clip of your exhaust by chance?
lol, that was my original question. Its just that easy tho right? get a cat, cut pipe put cat in pass test cut cat out weld pipe in and wait for two years right?
Man it's great living in a state where emission tests are unheard of. Whynot install a high performance, high efficiency catalytic converter? That way the car is running like it should, you suffer only a small amount on the sound, and you can pass emissions year after year.
well.... I dunno.. My exahust does kinda rattlecoming down from high rpmsbut thats kuz the guy sucked at welding and probably should get the whole thing re-hung.. I just dont want to sacrafice ANY sound... i want to beable to remove the cat after i test and then when i need it again in two years or w/e i can put it back in.
To answer a few of your questions from back in August(sorry, I must not have noticed), yes I always run premium, if you aren't you're suffering a decent loss in power. Unfortunately I do not have a clip of my exhaust, I've been trying to get a clip of it for some time, but I don't have a video camera and I don't know anybody that does(if someone wants to UPS me one, I'll be happy to make an exhaust clip asap!
). If you get a performance high-flow metalic cat typically you loose about 1 hp...if that. The only down side is that when you get the car tested sometimes it takes some time for it to actually pass because the cats will cool off while the computer is recallibrating itself. My car just got tested and it had to go through one whole test, then try again, and that time it passed on the quick test because the cats where warm.
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
#20
If i get a cat i dont need to go thru the trouble of getting any sensors right... i just need the actual piece? i mean its already been programmed for a cat delete obviously so im good to go, just pick one up and weld it in.
