-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   car accelerating on its own?? (https://camaroforums.com/forum/93-02-general-41/car-accelerating-its-own-49827/)
White94Z28 Mar 12, 2010 11:07 PM
well first of all its a 1994 z28 with the Lt1 and auto. aside from the other problems its having now my car seems to be accelerating on its own and the throttle is sticking. once on the street it even got stuck at high rpms and they wouldnt drop so i had to stop in the road and when i put it in park the car redlined like i was flooring til i turned it off. could someone tell me what might be wrong with my car please??
adam86107 Mar 12, 2010 11:31 PM
Maybe you can get some good info at a Toyota forum. lol I had to get that in there it was the first thing I thought of.
adam86107 Mar 12, 2010 11:46 PM
Toyota had a mass recall because of a similar issue.
White94Z28 Mar 12, 2010 11:49 PM
lol oh yeah sorry took me a minute to remember that problem killed some people if im not mistaken.
Gorn Mar 13, 2010 06:00 AM
There are a lot of thing that will make a car rev but the only way you can can enough air in the motor to red line the car is thru the throttle body.
Since you car is not drive by wire it is most likely the the cable(s), the cable(s) routing the throttle body itself.
Disconnect the throttle cable and cruse cable. See the the thottle body works smoothly and returns quickly. If not you it will need repair/replace it. If so next you need to chek the throttle cable hooked up. If thats all good I would drive it without the cruse hooked up and see if that makes a differents.
midrange Mar 13, 2010 11:22 AM
is this a toyota or somethign were talking about..
lol.. lube up all your linkages.. there is a spring on the throddle control that gets dirty, clean and lube!
Or move your floor mat. lol
White94Z28 Mar 13, 2010 08:05 PM
well i just lubricated all the linkage and the spring and it doesnt seem to be doing it anymore, but i havent driven it to far.
RFxCamaro Mar 14, 2010 03:36 AM
lmao i dont care if i live im a badass, i do crazy stunts, smoke like crazy, and drive toyotas i live on the edge
