car accelerating on its own??
Old Mar 12, 2010 | 11:07 PM
White94Z28's Avatar
Default car accelerating on its own??
well first of all its a 1994 z28 with the Lt1 and auto. aside from the other problems its having now my car seems to be accelerating on its own and the throttle is sticking. once on the street it even got stuck at high rpms and they wouldnt drop so i had to stop in the road and when i put it in park the car redlined like i was flooring til i turned it off. could someone tell me what might be wrong with my car please??
Old Mar 12, 2010 | 11:31 PM
adam86107's Avatar
Maybe you can get some good info at a Toyota forum. lol I had to get that in there it was the first thing I thought of.
Old Mar 12, 2010 | 11:46 PM
adam86107's Avatar
Toyota had a mass recall because of a similar issue.
Old Mar 12, 2010 | 11:49 PM
White94Z28's Avatar
lol oh yeah sorry took me a minute to remember that problem killed some people if im not mistaken.
Old Mar 13, 2010 | 06:00 AM
There are a lot of thing that will make a car rev but the only way you can can enough air in the motor to red line the car is thru the throttle body.
Since you car is not drive by wire it is most likely the the cable(s), the cable(s) routing the throttle body itself.
Disconnect the throttle cable and cruse cable. See the the thottle body works smoothly and returns quickly. If not you it will need repair/replace it. If so next you need to chek the throttle cable hooked up. If thats all good I would drive it without the cruse hooked up and see if that makes a differents.
Old Mar 13, 2010 | 11:22 AM
midrange's Avatar
is this a toyota or somethign were talking about..
lol.. lube up all your linkages.. there is a spring on the throddle control that gets dirty, clean and lube!
Or move your floor mat. lol
Old Mar 13, 2010 | 08:05 PM
White94Z28's Avatar
well i just lubricated all the linkage and the spring and it doesnt seem to be doing it anymore, but i havent driven it to far.
Old Mar 14, 2010 | 03:36 AM
RFxCamaro's Avatar
lmao i dont care if i live im a badass, i do crazy stunts, smoke like crazy, and drive toyotas i live on the edge
elyk10
Feb 16, 2011 02:38 PM
thor9812
Aug 29, 2010 12:14 PM
Joshsz28
Sep 15, 2009 09:59 PM
CamaroGirl1010
May 14, 2009 10:03 PM
Bzman
Apr 14, 2008 10:22 AM
