camaro trans problem
Old 03-29-2011, 02:39 PM
dogdog130's Avatar
Default camaro trans problem
well i got a problem well i put in new slave and master cyl around 2 mouths ago well i was driveing today and noticed if i am over 3k car wont gain speed but the englne is going strong yall think it the clutch or what
Old 03-29-2011, 03:58 PM
sure sounds like it. better get the service manual out and study up on changin the clutch.
Old 03-29-2011, 04:12 PM
dogdog130's Avatar
can i do it in my drive way
Old 03-29-2011, 04:21 PM
3800camaro's Avatar
Ya you can it you got 2 jack stands and a jack. You'll also want someone to give you a hand with it aswell.
Old 03-29-2011, 04:44 PM
dogdog130's Avatar
cool found a stage 2+ i am going to order and a light weight flywheel
Old 03-29-2011, 04:51 PM
just to make sure,,, the motor is reving up and the car is not going right? like your on ice but the rearend is not sliding all over and the tires are not spinning. also no clunking noises?
Old 03-29-2011, 04:56 PM
dogdog130's Avatar
it wont spin tires i can punch it and it takes forever but u can hear engine going full force
Old 03-29-2011, 05:08 PM
yep thats the clutch alright. probly better get flywheel, pressure plate and disk. at least get the flywheel checked and turned if needed.
Old 03-29-2011, 05:32 PM
3800camaro's Avatar
Make sure you get a clutch alinement tool if you don't have one.
Old 03-29-2011, 05:39 PM
dogdog130's Avatar
i will get one i am getting a alm flywheel, stage 2+ clutch ,presure plate
Quick Reply: camaro trans problem
