Camaro Halo Headlight repair
My drivers side halo headlight stopped working. After disassembling it and looking at the wires, the little "converter" box or something like that which changes the voltage from approximately 12-13 volts to a flat 1 volt (according to the volt meter used) and then splits into two connections to connect to the halo rings has a hole burned in it.
My headlights are similar to these http://compare.ebay.com/like/1904797...=263602_304692 and I assume all halos work about the same. My question: anybody know of a replacement part I can buy instead of buying a whole new set of headlights? Thanks PS: Yes I know halo headlights are "cheaply made" but I like them. Thats all that matters. Any help is appreciated in the matter! |
did you check at raidio shack or some place like that?
I thought about doing that but I'm not quite sure all the components needed.
| All times are GMT -5. The time now is 06:52 AM. |
