Camarillo 2002 won’t start
Old 05-17-2019, 04:00 PM
Nick Sisto's Avatar
Default Camarillo 2002 won’t start
At wits end. Ran out of gas now car won’t start. Have done everything! Anything suggestions
Tank Faulk. Fuel pump works. Gas at Schader valve. Car crank a bit won’t start. Spraying starter fluid. It fires bit won’t start continues to crank.
Old 05-19-2019, 07:31 AM
check fuel filter, remove and dump in clear container from tank side of filter, look for water and or crud plugging it up. if you dont got plugged filter or water then most likely fuel pump is toast. fuel at the rail doesn't mean you have enough pressure or fuel flow to make it run.
cardo316
09-19-2013 07:51 PM
flim101
01-07-2012 08:00 PM
imtico
10-16-2007 10:32 PM
r.serio
12-11-2006 04:56 PM
Joe7583
08-09-2006 09:14 PM
Quick Reply: Camarillo 2002 won’t start
