A/C clutch not engaging
It may be low on charge.
Get one of those R134A recharge kits, comes with a can of R134 and the trigger handle with a gauge. Follow instructions.
If sowem pressure registers on the gauge, then charge the system following instructions.
If no pressure is shown, you may have to have the system charged, checked for leaks using a soapy solution, fix the leak, then evacuated, and recharged.
If left with no pressure, might be a good idea to change the receiver/dryer as it would be contaminated with outside air, maybe, maybe not, but why risk it.
I want to add to this...I have a 94 that the compressor isn't kicking on...first made sure the compressor spins freely; it does, read about jumping the B1 and B4 terminals on the relay...did it and the compressor ran just fine, replaced the relay and still no compressor action until I jump the terminal..system only has about 12psi in it though...wasn't sure what the minimum charge required was to get the compressor to kick on on it's own
R134 is pretty cheap, Ollie's has it for $7 a can.
I would add another charge. You tool should have a gauge on it and after purging out the air in the hose, you should be ready to go.
Fortunately for your set-up, the system is still charged, meaning no need in evacuating the system and go from there.
Recharge first thing in the AM when static pressure is low.
Make a mental note for future reference, write it down somewhere along with ambient temp.
After charging, apply to all connections soapy water to find bubbles for a leak.
I use an spray bottle of 409, Mr. Clean, or whatever is available. Snoop is best and can be bought from the local HVAC store.
Emptied the AC can...gauge reads 32 or 33 psi...when the B1 and B4 are jumped the AC compressor engages and blow nice cold air...when the original relay is in there..nothing and when the replacement relay is in there nothing...only kicks on when those terminals are jumped....where to look now?
