a/c
AC worked a couple days ago now just blows hot air. Any ideas?
Leaking freon
^^ that about sums it up. buy a can of R134 and fill it back up.
I can't hear the AC clutch kick on do I'm wondering if that could be the issue
The clutch is not kicking on because you have a leak no freon. They make a kit that has dye mixed with freon. Find the leak replace it or seal it.
hit up autozone or whatever is local for you. they sell a UV reactive dye that you put in. Get a blacklight and find the leak. The compressor will not kick in if the freon level is to low some kind of safety measure.
same as mentioned above just a few more details. |
Ok I'll check it out
| All times are GMT -5. The time now is 04:58 AM. |
