Brake Pedal Goes to the Floor?!
Old Feb 5, 2013 | 07:16 PM
  #31
torque_is_good's Avatar
Yeah sure tigger, but you only suggested a leak in post 3.
Take a looky see at post 6, where it was suggested by one of our highly respected members that it very well could be air still trapped in the system, in addition to a possible aforementioned leak.
whistle...whistle...whistle.
Oh and darth, one word: "speed bleeders", look em up!
bleeding?
oh, I had a heck of a time bleeding my master clutch cylinder on the honda.
to those who must bleed their brakes I give you Alice Cooper
Old Mar 5, 2021 | 09:09 AM
  #32
edecisions's Avatar
I'm going to offer this up as a possible cause as I just went thur this very issue, I replaced everything, same issue, what fixed it was a simple adjustment of the clevis to peddle, not longer shorter, I found that the plunger was not fully pulling back because the clevis was adjusted out so far that it always kept the the master just slightly depressed. Its my belief its required to come all the way back so that it can drawn in more fluid if needed. After replacing everything I found that adjusting in 3 turns of the clevis on the thread and wam! I got strong flow out the rear brakes.
Best of luck to all.
Old Mar 5, 2021 | 10:25 PM
  #33
Please keep an eye on the post dates.
Old Mar 6, 2021 | 05:15 AM
  #34
edecisions's Avatar
oh, I see, so like no one has this issue ever again after the post date, I know it was old, I spent 1000 and 4 months on this, I’m pretty sure the guy that has this issue in 2050 won’t care that I posted I. 2021, as I spent weeks searching I just wanted to post my fix for the next guy, by the way what are you doing reading such an old post?
Old Mar 6, 2021 | 08:03 PM
  #35
No reason to pull up old posts. Just make a new one. It should says here was the issue I had and how I fixed it. If I was researching a brake problem and I read through a thread and the original poster said after 27 posts, OK I fixed it, the brakes just need bled correctly I seriously doubt I would continue to read the posts after from people saying "I was right" just to get to your post that has good info. I would have just thought there is 2-3 minutes of my life I won't get back and flipped backed to the search. Now a post that has straight forward info and a few "thanks that helped me" is what you want to help the future.
Keep in mind that a lot of people subscribe to threads they post in and get email notification when those posts are reopened. If everyone posts in post that are 5 to 15 years old then the site is basically sending out useless spam .
deebsr6
Oct 29, 2012 11:23 PM
jasunf
May 3, 2010 10:46 AM
95z28htch
Feb 21, 2010 06:46 PM
Lisa7
Jun 11, 2009 12:28 PM
sPaC31
Jan 5, 2009 06:45 AM
