Bosch Platinum 4 Y/N?
Old Jun 4, 2011 | 10:19 PM
stainless1911's Avatar
Default Bosch Platinum 4 Y/N?
I put Bosch platinum 4 plugs in , and a couple people told me that I should change them out to the AC Delco plugs because I would probably just continue to have problems with it.
What say ye?
BTW, any suggestions in removing/replacing the #1 (under the alternator) spark plug? I have an AIR pump and A/C. It took me 2 hours to r&r that plug. My arm is still sore from trying to get in and out of that very tight spot.
Old Jun 4, 2011 | 11:11 PM
RFxCamaro's Avatar
Snap on makes a good swivel socket for spark plugs, it changed my life. AC Delco is oem, I dont know why ngk would be a problem unless it is the wrong length.
Old Jun 4, 2011 | 11:14 PM
ngk?
Old Jun 4, 2011 | 11:22 PM
Katzen's Avatar
i like my bosch pl4 in my 92, they lasted us for 9 years now
Old Jun 5, 2011 | 04:12 AM
Massey's Avatar
I have had many customers bring the +4s back after putting them in the larger lower revving engines. Now in small displacement high revving engines they do just fine.
NGK makes a great plug, the iridiums are a little spendy but good. AC Delco plugs are OEM and in 93-97 they were platinum and 98+ were Iridium.
Personally I would not use the Bosch +4 plugs in anything. Keep with the standard plug design you should do just fine.
Massey
Old Jun 5, 2011 | 08:26 AM
ngk tr55ix are the best i could find to use in the lt1. have used +4's with and without issues once the motor was built the lt1 did not like them or the acdelco. i use a long handled rachet with the swivel head and a short plug socket, with extention on ones that need it.
Old Jun 12, 2011 | 10:16 AM
Bosch platinum 4 gave me a PO300 code, random misfire. Changed ONLY the plugs to AC Delco, and the code is gone. Car runs fine.
Old Jun 12, 2011 | 10:32 AM
All you need is one good spark.
Old Jun 12, 2011 | 11:07 AM
And one good woman.
Old Jun 12, 2011 | 09:43 PM
libertyforall1776's Avatar
Denso Iridium is my choice. Here's a little info on Denso vs. OEM:
- Camaro RS V6 Project Car
FRANK121
Oct 14, 2010 08:41 AM
BLK_SS
Dec 1, 2007 11:39 PM
blackbird22
Jul 13, 2007 07:00 PM
libertyforall1776
Jun 7, 2007 12:38 PM
