Blinker
Blinker
My left turn signal bulb is out, so I went underneath the car but the screws are so rusted, when I try to turn them they rip the fender? (w/e its connected to, im new at this lol), anyone have any ideas?
By the way its a 97 RS, just the 6 cylinder, Ive got some money saved up for a new exhaust, Ive heard the Magnaflow is good, I would love a Borla but they seem too expensive.
RE: Blinker
Yup this happends alot and what i did was give the driver side tail lights a little wack and it worked (not a good idea) then when i got cold i just broke the dam thing and ended up buyin aftermarket taillights for like 90 bucks...so dont do that and learn from my mistakes....anyways the first thing you should check is the bulb...there are two wing nuts, one is under your speaker in the trunk and the other is behind the carpet...should be very easy to find then find out which bulb it is and replace it even if it looks good...the filiment on the inside usually cracks and thus it doesnt work......thats what i wish i woulda done...hope i helped and good luck
RE: Blinker
Im assuming you mean the front blinker corners, and not the tail lights. If you cant get the bolts out, im not sure if there is another way to change the bulb, but maybe someone else knows. But, from what I hear, BadinfluenceRS may be selling a Borla system sometime.. Wouldnt be surprised if he posts in here sometime..
