Berger panels...??
Old May 4, 2011 | 11:58 PM
milkshakeman55's Avatar
Default Berger panels...??
I was considering doing a berger panel on the back of my camaro...
Just seeing what y'all think about the berger panel. Im a big fan of the satin black!! But dont know if a gloss black would look better, due to my rally stripes.
If anyone can give me tips on how to do this, like what brand of paint to use, or anything of that nature, it would be greatly appreciated!!
satin black
Gloss black
Old May 5, 2011 | 12:05 AM
timmyz28's Avatar
I used Duplicolor acrylic black spray paint for mine. I took it off, sanded it down so its smooth, sprayed about 3-4 coats, and then that was it. I went for a flat black look so I didn't clear coat it.
Old May 5, 2011 | 12:12 AM
RFxCamaro's Avatar
I like the satin black. Just pulled mine off a black ss
Old May 5, 2011 | 12:13 AM
So if i just threw a clear coat on it it would look glossy black? cause if thats the case, then i will just do a flat black and if i dont like it, just trow on a clear coat later.
Also, how is the paint holding up?
Old May 5, 2011 | 12:21 AM
timmyz28's Avatar
The paint holds up for a little while but will start to chip if you do flat black. The clear coat acts as a protector basically. And if you do clear coat it, wait for the black to completely dry so the clear and black don't mix. This will make it look cloudy.
Old May 5, 2011 | 12:26 AM
ok cool. And would any black paint from duplicolor work. Like could i use flexible bumper coating or should it be something else?
Old May 5, 2011 | 12:46 AM
BasicConcepts's Avatar
Technical User
if you like the flat look you can use satin clear it still protects but doesnt shine
Old May 5, 2011 | 12:50 AM
hmm ill probably end up doing a glossy black to match my stripes.. lol
but you cant really see my stripes from the rear anyway....
Old May 5, 2011 | 02:04 AM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I need to get stripes for my wing now that I have the ss wing. Why don't you just play with that supra in the garage instead :P
Old May 5, 2011 | 09:58 AM
Z28Freak's Avatar
Do you guys think a black berger panel would look good on my green Z28?
