Back in black. got me a Z
a 1994 z28. its black flowmaster exhauster 70k miles it runs pretty solid. just did a tune up on it and put a new airfilter on it because the original was gettin old. its only got two problems one is its got a light on the guage i know my camaro had it before and i fixed it. its a red square with an arrow pointing to some liquid or something. i cant remember if its gas tank or radiator. the 2nd problem is the left turn signal works but the right one when i hit it the arrow doesnt flash and the signals dont blink. is this the switch or what? ill get some pics up soon its beautiful body is damn near flawless needs to be buffed tho its got some swirl marks.
That should be your turn signal relay, under the dash to the right of the steering wheel. Mine did the same thing, one side wouldn't flash. And welcome back to Camaroville!
Or it's a bulb gone bad... Which is easier to find and more likely. Turn it on and leave it on then see which bulb isn't lit. If both are lit, then it's the relay, if one is out, voila, bulb =D
ok ill check it out 2morrow. what about the redbox with arrows light?
Anyone?
I THINK that's your coolant level warning... May be a bad sensor if your coolant level is good though.
