auto to Manual???
Old 01-29-2010 | 05:39 AM
maudyZ28's Avatar
Default auto to Manual???
Alright guys has anyone done this change??? I've read up on it and am pretty sure I know wht i need, just wondered time it may take.
Also does anyone know if I can use a T56 box from a GTO rather than a carmaro ???
I have currently have LS1 V8 with 4L60E
Old 01-29-2010 | 12:55 PM
libertyforall1776's Avatar
There was a write-up in GM High Tech Performance:
http://www.gmhightechperformance.com...ion/index.html
Old 01-31-2010 | 06:40 AM
maudyZ28's Avatar
thanks for the link liberty but I aleady had it, i know what parts im just kinda checking if anyone knows of a reason why I could not use a GTO T56, i can get thoswe in UK easily vs. a standard camaro one
Old 01-31-2010 | 11:24 AM
wicked's Avatar
that would be interesting to see i have thought about if that was possible before for my lt1 i hope you can do it i would love to see it
Old 01-31-2010 | 11:33 AM
maudyZ28's Avatar
i've subsequently found out the bolt up is the same, and the internals are uprated and the gear ratios are slightly different , but the main possible problem is the shift lever is different and is sat 3 inch further back. I dont know if you can swap over the camaro one, but the point is I cannot get a camaro box let alone any parts for it (with paying an arm or leg) so the GTO was better, now i still might concider auto rebuild like my original plan ?????
Old 01-31-2010 | 05:40 PM
wicked's Avatar
probably would be a whole lot easier but not as interesting and im most likely just gonna get a shift kit
Old 01-31-2010 | 05:50 PM
maudyZ28's Avatar
front the looks of the read up it should be too bad, but im gonna need efi live to swap tunes and all the associated pieces shipped to the UK, and then i've gotta try and find a pedal set?? The point of getting a gto box is the they exist in the UK as Monaros, but camaros are really rare, specially a manual. Ill see how the plan goes down the line. Im pricing everything up at the moment and have to see when i get paid when i start my phd
Dcapper81
04-10-2012 04:36 AM
305_camaro
10-27-2011 06:33 PM
r6rider
06-30-2009 02:43 AM
BowTieRidin
82-92 V8 Tech
14
02-24-2007 06:47 PM
camarocav
09-18-2006 06:44 PM
