anyone know the range spec for the MAF
Old Apr 2, 2011 | 09:35 AM
auto's Avatar
Default anyone know the range spec for the MAF
tried looking all about with no luck, my friend is bringing over his multi meter so we`re gunna test the MAF but i need the range
Old Apr 2, 2011 | 06:07 PM
i cant find anything on em as far as ohm or volts.
Old Apr 2, 2011 | 08:24 PM
auto's Avatar
i could not either, but if i stick a volt meter on it and run the car and rev the engine, and the number increases, would that mean the MAF is functioning as it should??
Old Apr 2, 2011 | 09:17 PM
means its doing something dont know if its right though. if i had a factory book for a newer obd i could look at the data values. mine only shows the map.
Old Apr 3, 2011 | 11:27 AM
maudyZ28's Avatar
even if it was NOT running using the maf the 98-99 VE table it would default to use if the MAF wasn't working is pretty accurate and it wouldn't have such bad gas milage as you are getting.
Chevy101
Oct 26, 2011 03:44 PM
emperorclobbersaurus
Feb 3, 2010 08:42 PM
Bblock
Jul 18, 2008 05:51 PM
PsyDoc
May 5, 2008 06:32 PM
Altekameraden
Jun 29, 2007 12:01 PM
