Anyone here have a Borla exhuast?
Old 03-06-2011 | 09:06 PM
Diesirae's Avatar
Default Anyone here have a Borla exhuast?
I've got an annoying rattle that I can't figure out where it's coming from, it's a clearance issue somewhere with the borla setup, didn't have it without it, curious if there is a common point where the setup typically rattles on the 4th gen.
Old 03-06-2011 | 10:30 PM
3800camaro's Avatar
Sounds like it could be a loose pipe. Try tightening every clamp as far as you can.
Old 03-07-2011 | 12:38 AM
RFxCamaro's Avatar
Yea I have a borla no rattles
Old 03-07-2011 | 09:06 AM
SpecterGT260's Avatar
Ninja Administrator
none on mine either. Make sure everything is fitting together correctly and that the clamps are catching both pipes at every union.
Old 03-07-2011 | 12:03 PM
are you missing any nuts or bolts. may have one in there bouncing around. i had one in the header collector on one side, had fallen down from up top and managed to get into the cubby where the pipes all come together. had to find a tiny telescoping magnet to get it out.
Old 03-07-2011 | 02:02 PM
libertyforall1776's Avatar
I have one, and there is some rattle from the heat shielding vibrating on the passenger side rear -- haven't looked into it yet. Its tubing also hits the body on bumps which is really annoying -- need to do some tweaking when the weather gets warmer...
Old 11-02-2011 | 02:35 AM
DanielWEWO's Avatar
Yeah, i have a borla in my 96 z28. I have the rattle as well. At first I thought it could be a bolt or something, but I checked everything and there is still the rattle.
I read other places that it could be the muffler hitting the heat shield... it doesn't sound like that kind of rattle but i'm going to check it out. i'll let you know how it goes.
Old 11-02-2011 | 09:22 AM
garyZ28's Avatar
Was never really too impressed with Borla, I have Spin Tech on my 96 Z and it sounds great and no rattles. We had the same problem with my sons car and it turned out to be the heat shield on the cat.
Old 11-02-2011 | 10:01 AM
another heat shield in the back by the fuel tank.
Old 11-02-2011 | 10:33 AM
iLL95's Avatar
I Like to Party
Super Member
Hahaha ok craby now your pic is pimpin
