anyone good at math???
i wanna build s set of caster dollies for the camaro so i can move it around the garage... i figure i can build some rectangles out of 2x4 and just bolt on some casters but i dont know if im doing the math right as to what size casters to use
i figure 4 casters per wheel = 16 casters
250lb casters
so...
250x16=4000lbs
so if im right i should have no problem holding the car on those right???
(i failed every year of math in high school im more of a shop class kid lol)
250lb casters
so...
250x16=4000lbs
well as of now (and just about as long as ill have the car on these) theres no motor or trans in the car so i figured that cut quite a bit of weight
6000lbs = 375lb casters... the biggest i can find (not online) is the 250s
With a curb weight of almost 3300 lbs. (with engine and trans) and figuring a 60 front/40 rear split to be safe, you'll have around 1980 lbs. on the front. Divided by 8 casters puts 247.5 lbs. on each. You're teetering on the line of failure, go with heavier duty casters. You may want to use them again, on a fully dressed car.
This will do, but you might want to use a high power jack, putting 2 wheels up at once. That way you have it secured. Just an idea.
24 casters @ 3.50 = $84, plus tax. Then the lumber, fasteners, and time to assemble them. Or.....car dollies | eBay
