any ideas
I have a 1997 Z28 bone stock, auto transmission. The problem I'm having is that sometimes, not always if I drive for lets say 20-30 miles and shut the car off when I go to start it again it starts up but runs really rough, to the point where it finally dies(acts like it floods) ,So I talked to a couple guys about it and they seemed to think it could be a bad fuel pressure regulator, well I checked fuel pressure as the book tells you to results were, with key on engine off 28-30 psi no drop of pressure after 5 minutes also no drop when i put 14 inches of vacuum to the reg. no change with engine running either.
Also pulled a P0441 code. Any thought would be appricitated. Sorry for the long post. Thanks in advance. |
i think we need a sticky for this. lol. po441 has to do with the evap system. heres a thread on the 93 and i think its very close to what u have. could be as simple as a new gas cap.
https://camaroforums.com/forum/lt1-lt4-tech-9/testing-evap-system-51219/ |
heres more thats is more specific to your code.
https://camaroforums.com/forum/showp...95&postcount=8 |
