air hissing through driver window top when driving 50+ mph
how i can i fix this? i have the window all the way up but when i go 50 or + its like pssssssssss and really annoying....i try to pretend its a supercharger but its not working.
I think theres a gap between the driver side window, because it was broken and just got fixed....can i replace the weather stripping or what should i do? how hard/expensive is it?
t-tops seem to lock in fine with no gaps or air coming in.
When the window was replaced, they didn't adjust it properly. To fix, you need to go inside the door and mess with the mechanism. Not sure if that's at or above your present pay grade?
i suck at working on cars so i cant do it and i dont want to duck tape it, and i cant just go in through passenger side.
will itbe okay if i just tyr to ignore it? i should eventually get used to it right? maybe play the radio or something or rock with t-tops? girls will still like my car right?
i dont really like how those look, is it okay if i just try to ignore it? what would u guys do if u were me?
I am not saying that window adjustment is not the problem, it most likely is but, How does the door close? What condition is hinge in. A very common issue with the Camaro is the bushing in the hinge wears and allows the door to sag, over time the sagging causes the door striker to wear and the back of the door will drop just enough to cause air and water leaks right at the back corner of the window.
To fix this the hinges need rebuilt the striker needs replaced and the door needs realigned.
