Aerial
Old Nov 11, 2013 | 04:24 PM
01Firebird's Avatar
Default Aerial
How do I get the power aerial to go up and down? Does it operate automatically?
Old Nov 11, 2013 | 06:51 PM
If you are talking about the power antenna, yes it automatic. As soon as the radio turns off the antenna goes down.
Old Nov 12, 2013 | 05:56 PM
GaryDoug's Avatar
If the antenna motor does not work, you can always pull it up manually. You may need a "hook" to reach inside the antenna bezel however.
I got tired of seeing mine go up every time I played a CD, so I unplugged the motor. You may want to check to see if that was done on yours.
