Advice assisstance needed!!!!
I am changing my optispark and everything is going fine but I cant get my harmonic / crankshaft pulley off. I have taken all 4 bolts off of it and I am using a harmonic pulley remover. I have been stuck doing this for 3 hours and still cant get it off. I used wd40 and many other lubs but nothing gets it loose. I cant break the damn thing loose. What should I do or any tips
Pics? All references I've seen show three not four bolts. Scroll to the bottom.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
I took all three on the outside and even the one in the middle and even used a torch to heat it up and then used the harmonic puller and it still wont come off. Is there a hidden bolt or somthing. what am I missing
You need to partially back off the center bolt and then pull the hub out till it hits against the center bolt. Back off the bolt again & repeat till the hub is all the way out. When the hub is finally out you will see why you had all that trouble.
I figured it out. I was using the tool that you use bolts. You screw the 3 bolts in yada yada yada. Well I noticed that it was going all the way through the hub so I went and got the puller that has the 3 claws it came off on the first shot.
