AC problem
Old Jul 21, 2012 | 10:48 PM
jimtin's Avatar
Default AC problem
i bought a 94 Z28 two months ago the ac was very cold up until now it just blows out hot air i parked it two weeks ago the air was working drove it two days ago no air i checked the refrigerant which was full the compressor comes on if put wire in place of the relay same for the fans but still hot air with both on please help me this has got me stumped,thanks
Old Jul 22, 2012 | 12:17 AM
How did you check the refrigerant?
Old Jul 22, 2012 | 12:35 AM
This doesn't belong in the Ask GM section. Moving you to 4th gen.
Old Jul 22, 2012 | 07:19 AM
jimtin's Avatar
I checked with a gauge on the low pressure service port
Old Jul 22, 2012 | 08:52 AM
MKCoconuts's Avatar
Depending on what gauge you used, some won't tell you how much refrigerant is in the car until you start adding some from a can.
Old Jul 22, 2012 | 04:07 PM
jimtin's Avatar
That's what i did
Old Jul 22, 2012 | 05:02 PM
2Z's's Avatar
Maybe your plenum doors arent working correctly. I know they need vacume to work properly. I think theres a hard plastic line on the manifold that feeds the vacume for the plenum door operation.........
Old Jul 22, 2012 | 08:55 PM
jimtin's Avatar
Ok I'll try that tomorrow thanks
Old Jul 22, 2012 | 09:40 PM
slick's camaro's Avatar
Check the back of your thermostat panel. If that plastic clip breaks or slips it could be stuck on heat on the back side if your constantly changing the temp settings.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
