Abs inop light
Ok, I'll check this tomorrow, I had a magnaflow installed about 2 months ago. The abs inop light is a fairly new problem, but who knows. Could be that sensor connector and I'll check the front one's too. After that I really look everywhere. It was so simple with my 69 impala, no gadgets never had problems except it like gas alot lollllll
my inop light has been on for a little while but i found some vacuum lines off...hooked them up and it went out...came back the next day and started it and there it is again...i am soo ready to get this one straightened out...
![Thumbs up](https://camaroforums.com/forum/images/icons/icon14.gif)
Update........
Fixed my inop light problem. My camaro has an after market wing with led lights.
Sense the led lights don't have a filament in it like normal bulbes, you have to put
a resistant in the line. The easiest was way to simply add a relay and connect the red or blue wire to the 86 pin and the black wire to the 85 pin and voila. Light
stays off and cruise control works perfect. when I connected a scaner to the car,
it gave me 5 abs problem codes. every thing abs related had a problem lollll.
Here is a pic of how to fix from shbox. Love the site. Hope this helps others with same problem.
![](http://shbox.com/1/relay_for_ss_spoiler.jpg)
