abs, inop
these lights are always on and im just wondering are they supposed to be. its the abs light and another one INOP
RE: abs, inop
No, they are not supposed to be. If the light is constantly on and not blinking that usually equates to a wheel speed sensor either loose or giving bad data. Try making sure the sensor is making a good connection to the wire connecting it, if everything looks good there you may have to replace the sensor or the special flexible wire that connects into it. Good Luck!
RE: abs, inop
Also check your alternator if it's charging. My abs lite came on when my alternator plug was loose.
RE: abs, inop
right before my alternator died after i installed my sound system my abs inop light came on and at a complete stop my speedo said i was doing like 20mph. Then i got a new alt. and all the problems went away.
RE: abs, inop
this two lights are always and on and have been since ive had the car they aren't blinking. and lately my brakes seem horrible like if im going past 55 and i have to hit the brakes the whole car shakes. the front brake pads were changed late august could i need new rotors?
RE: abs, inop
Sounds like it. Get new pads as well.
RE: abs, inop
The shaking is caused by warped rotors, and warped rotors will also cause the ABS to complain. Also check that the high mounted brake lite works, as a bad one will cause the ABS to complain.
RE: abs, inop
where is the wheel speed sensor located?
RE: abs, inop
Front sensors are plugged into the front wheel hubs. Rear sensors depend if the car has traction control. No traction control, sensor plugs into differential housing, With traction control sensors are located by each rear wheel (follow the wires).
RE: abs, inop
