97 Z28 trans pan torque specs?
Can anyone tell me the torque wrench specs for my transmission pan? Previous owner had just changed fluid and filter on it before I bought it. It's been leaking and I'm pretty sure it's from around the pan gasket. I want to tighten it but want to be sure I don't overtighten or warp it.
Thanks! Jeff |
Nevermind. I found it in my Haynes manual in the front where it discusses trans fluid and filter change instead of in the transmission section where it should be.
I use 80-100 in-lbs on pan bolt but you can download Some of the GM manual from the manual section.
Thanks Gorn! Where is the manuals section? I can't seem to find it.thanks!
