97 Z28 question?
well could be a few things, if you have a cold air intake, it could be sucking the water in when it rains, temporaily throwing check engine light, or it could be the opti not liking the water too much....could be other things though
does any region in the engine area look to get really wet, water in plug sensors etc would cause the light to come on if there are misreadings, just because you mention it doe sit after a wash?
Does it only do it on start up in the rain and after a wash or does it come on after driving say 20 mins??
this points to the opti, wires, or plugs are getting wet or moisture in them causing a bad spark and hence the missfire, unless as craby says its in the PCM and its causing the car to go 'mad'
