97 Z28 Fog Lamps - How to Remove
Old 09-22-2009 | 05:01 PM
rockinroller's Avatar
Default 97 Z28 Fog Lamps - How to Remove
Anybody out there know how to remove a fog light on a 97 Z28? My lens is broken on the driver's side lamp and I went underneath the car to see if there's an access point to unbolt the assembly and there doesn't appear to be any (unless it's "hidden" behind the entire front lower fascia, requiring removal first). I also didn't see any access points from above, in the engine compartment area. There appears to be a center, top screw for adjusting the height of the light, but that's it.
Thanks.
Old 09-22-2009 | 05:16 PM
gotta take the lower fascia lose and a couple bolts and another peice, then u can get under there to change it. just like everything else on the cars it will probly draw blood. changin bulbs is just as bad.
Old 09-22-2009 | 05:37 PM
02StanGT's Avatar
two ways. one is to remove the plastic pins where the housing would pivot, and remove the adjuster screw, and voila. or you can go underneath the fascia part and remove the fog light bracket.
Old 09-23-2009 | 06:58 AM
Thanks for the info. Sounds like I better get the Band Aids out first.
ZZ04
04-18-2011 06:49 PM
ChevyManCam
01-15-2011 04:12 PM
Frannyj
06-09-2009 10:50 AM
car5car
03-08-2008 12:39 PM
greg w
06-23-2007 07:47 AM
Quick Reply: 97 Z28 Fog Lamps - How to Remove
