96 camaro window prob
quick question, does your radio work? i only ask cause what are the odds both window motors go. i kinow that there is wiring issues when it comes to the windows, and if it is the wiring, then the radio should not work either.. but if your radio is good, then i'm sure its a motor issue.. but thought i'd throw it out there.
Well apparently I didn't know you have to roll the window up then put in a screw, then roll it down and put another and so on and so forth, well I managed to bolt it on with some screws I bought at autozone but now I have a small problem, when the window reaches the top, it stops like 1 and half inches before it reaches the top cuz it kinda of tilts and like gets stuck, ughh.. I think a little piece of that cushy material fell of cuz it was so old, not sure if thats whats causing it..
Well I figured it out, turns out when I installed the motor, the metal on the regulator thing bent a bit while I was putting it in and caused it to get stuck, I had to remove the motor and bend it back and place and now it works like a champ. Now Im happy
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
okfarris
05-14-2010 09:43 PM
