96 camaro window prob
prob one need new power window motors right and left are these hard to replace? and the wether striping where window rolls up and down the clips are broke do you have to buy the whole strip or can you get just the clips?
Not sure about the weather strips but the motors are not to hard to replace. If the original motors are in the windows, you will need a drill to remove the rivets that hold the motor to the door. When you buy the motors, be careful not to loose the screws and lock nuts that are in the box. That will be what replaces the rivets. MAKE SURE YOU DRILL OUT THE RIGHT RIVETS! Do a search on this site, I think there is a post with pics and step by step instructions.
Never mind the search! Found the link.
https://camaroforums.com/forum/93-02-general-41/how-change-4th-gen-window-motor-13164/
i used oemforless for the window felt and guide pads. wanted the oem parts not some china stuff. it was about 60 bucks for one side, window felt and pads. yes u need to replace the whole thing cant just do the clips. my windows are alot cleaner and no funky marks were the worn pads were rubbing.
https://camaroforums.com/forum/93-02-general-41/replaced-outer-door-felt-seal-48214/
I am trying to replace the motor on my 94Z. Only problem is I can't get the motor lined up properly to screw it on, and to top it off, it came with those rivet things, I was like wtf. I looked at this already https://camaroforums.com/forum/sh...ad.php?t=13164
but mine doesn't look exactly like it, mine has 4 rivets instead of 3, but thats not the problem, the problem is I can't align it properly. Has any1 replaced the motor on a 94Z and had that same problem before? I image it should be just like the 95 but guess not. I also need to get some screws n nuts..
btw. I bought the motor from GM and it was hella expensive, like $169 ouch.
i picked up a oem regulator and motor for 110 bucks on ebabe, work way better than the aftermarket motors. have u looked here?
http://shbox.com/page/windowmotor.html
