96 3.8 camaro missfire
hello, looking for some help here.
hava a p0304 (or what ever the misfire in cylinder 4 is)
missfires at iddle only...and throws the code consistently.
changed coil that goes to 4
chaged spark plug on 4
tried a different wire on 4 (certain it isnt wire and it didnt burn on headers)
even changed 2 and 4 injector
was just wondering is there anything else besides low compresion on that piston that will cause this?
another note......... my catalyst is rattleing going to change it out on Friday that couldnt be it could it?
thanks for any help in advance,
if you need more info please ask.
Im trying to make it pass smog to keep it as my daily driver.
Are you saying the crank sensor can detect one lean spraying (clogged) injector?
You could try to change the plug and wire for 2. The way the coils work it could cause an issue. How did the plug look? Have tried a spark tester to see if it is firing? It could also be the Module or a small coolant leak into the cylinder.
The crank sensor does not know or cares about what causes a misfire, the only thing it does is to report the crank position to the PCM every so many degrees of crank rotation.
Ahhhh ok. So in a lean cylinder condition for instance, the crank sensor is picking up a momentary drop in power in that cylinder, then assumes it's a misfire. That's what was throwing me with what you said, I've never considered a lean fuel supply issue a misfire, but the PCM does because it doesn't know any better.
