95z quit running and now wont start?
Old 05-27-2010, 10:03 AM
locotrician's Avatar
Default 95z quit running and now wont start?
so my car is a 95z28 m6 its heavily modified, i got the car from a guy that owed me money so i dont know a lot of the exact specs but this is what i know, its got a full exhaust edelbrock headers, world heads, bbk dual throttle body, the intake is not stock but i cant say for sure that its the lt4, its got a comp cam of some sort and comp roller rockers,the car is lowered and its got a paxton supercharger on it. the fuel lines are braided ss and its got a vortech fuel pressure regulator. i was driving it and it stopped responding to the throttle and then it wanted to shut off , i could keep it running if i stayed on the gas but i wouldnt idle on its own. it did restart once and ran ok for a half mile then same thing again and it now will not start . it does turn over good. the car has gas in it and the fuel pump does run the car has run really rich ever since i have owned it. i know this sounds like a fuel problem and it may be but im leaning towards something else being the problem. any input is appreciated and thanks in advance.
Old 05-27-2010, 02:05 PM
osduck5's Avatar
Have you checked to see if you are getting fire to the plugs? Any codes?
Old 05-28-2010, 11:16 AM
yes i am getting spark however i only pulled one wire and check it the service engine light is on and has been on since i got the car. i lost my code reader but the car is at my uncles garage at the moment he is gonna run the codes but i havent heard back from him yet.
Old 05-28-2010, 12:51 PM
are you having fun with the double post. kinda the pits saying the same thing over and over. good practice for parenthood.
Old 05-28-2010, 01:48 PM
im not following what you mean by the "double post" are you referring to me posting my issue in both the general "fourth gen" forum and the more specific "lt1" forum ? if so i thought this would only make sense since both of these categories describe my car. if this is against the forum rules i apologize and will remove one of them.
Old 05-28-2010, 01:55 PM
im funnin, i noticed u posted the same answer in both. i think your ok or a mod would be given u a hard time. hope u get it figured out. have a look at the map as well. failing map can do some strange things. could just need cleaning.
Old 05-28-2010, 02:34 PM
osduck5's Avatar
LOL at craby! I was thinking I had already replied to the post then realized it was posted in 2 different places.
Old 05-28-2010, 07:22 PM
ok i really didnt think of the map but thats a good thought thanks,
Old 05-28-2010, 11:59 PM
The reason why it's smarter to only post in one place, is because one persons answer can sometimes make another person think of something else.
It's called brainstorming, but I think I feel a little fog rolling in right about now...
Old 05-29-2010, 03:29 PM
darkrods's Avatar
Mass airflow or it could be your ecu hate to say this but you should have your ecu data loged youll likely find your problem faster.
Quick Reply: 95z quit running and now wont start?
