95 camaro died while driving
I have a 1995 camaro automatic. I was driving on the freeway and the car died(no power breaks, steering, nothing) but the battery is fine. Still have radio windows and all that good stuff. My security light was on but not flashing because of a ignition cylinder that gotten changed out awhile back. never went to the dealer to have it cleared. Now the car won't even try to crank over. Thoughts?
have you tried just disconnecting the battery for say 30 minutes? I had issues with that security light when I first got my camaro. I disconnected the battery and left it overnight... everything worked fine in the morning.
i have a similar problem, i'll be driving and it'll be fine till i shift into neutral and coast it just shuts off and sometimes the steering lock comes on =X i still haven't figured out what the problem is but i never thought to d/c the battery i'm gonna try then when i get it back from the shop tomorrow.
I have a 96 v6 and a few years ago I had a similar problem. I had parked my car at a gas station and when I came back out my car would not start or turn over and the security light was on solid. I tried disconnecting the battery but it did nothing. I had the car towed to the dealership and found out that the sensor in the ignition (not too sure of the exact name of the part) for the computer chip in the key had gone and my car essentially thought I was using the wrong key, which I wasn't. I had to get a new ignition sensor and new keys. The worst part was that I was 2 hours away from home and I could have had my GM guy fix it for a lot less than $400. Good luck!
u can have the vats programed out of the ecu by a place like this
http://www.pcmforless.com/index.php?...d=44&Itemid=40
u can get one of these
http://www.ecklerscamaro.com/product...dept%5Fid=1620
or u can make one
check the fax and tech on the 4th gen page
or u can make one
http://shbox.com/1/vats_bypass.jpg
