95 Camaro
Coolant leaking...don't know from where? No puddle on ground. And...no heat. Ugh.
Have had this issue numerous times. Please assist. |
what engine? what's the oil look like?
Not sure what u mean...
Originally Posted by Lovemy95redcamaro
(Post 730584)
Running it that way will mean an engine failure soon. |
Thanks...I'll check oil.
happened twice before...I've had 2 used engines in 10 years. Ugh. |
happened twice before...I've had 2 used engines in 10 years. Ugh. v6 |
3.4 or 3.8?
(Post 730589)
Hi.
I'm going to swap engine. getting one with 80,000 km. for $500.00. less expensive than to fix head gasket issue. |
You are installing an engine with a 23 year old engine/head gasket and its been siting without running since the car wrecked and you expect it to last? You will be lucky to get a year out of it and not have a major failure. Heck you could blow out the rear main in a few weeks. Replacing parts on an engine that is out should not be expensive. For 5-$600 you could do oil pan, front and rear main seals, head and intake gaskets and have an engine that is ready to run a 100,000 miles.
