'95 3.4 Camaro base. Vacuum part
Hello All
I have been desperately trying to find part 10044942-fitting asm intake manifold Rubber vacuum T. It is discontinued, Dealer, salvage yards, parts stores...impossible to locate.
Anyone out there have or know where I can purchase this...if any availability exists? If not, is there an alternative to repairing it. It has a crack and the car is running, but will run so much better with a new or good used one, If it goes altogether, I know that's big trouble.
Thank you for any guidance.
Since the parts discontinued, there isn't any other choice than go to a pick-a-part and find a good one. I've had to do that with several small plastic and rubber parts for my car, and if there is a good selection of cars you can usually find an intact part. But, if it's something that cracked on just about every car over time there isn't much you can do about it.
Thanks for your response. That is what I was thinking, and I just missed a parts Camaro on Craigslist. Will keep searching. The 3 fitting sides to this vacuum piece are all different sizes, can't comprehend why they designed it like that...
