-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   94 z28 issues ?optispark? (https://camaroforums.com/forum/93-02-general-41/94-z28-issues-optispark-88223/)
powellwfp@yahoo.com Mar 9, 2026 01:10 AM
hello, been trying to get my z28 back on the road... well got it running but not too well, put on new optispark, tested before installing for testing I hooked up the opti and used a drill to drive the gear and tested each port and all had spark, I installed the thing and just drove it around the block and started back fire and not running too good. I used a temp gun and pointed at each cyl header pipe, nr 1 was only around 150 degrees all others were around 350. i checked the plug wire and still same on next test except now nr2 cyl is also at 150... but now also cyl 5 is reading around 500...i then checked for spark on 1,3,5,7 and 2 cyl's all have spark, I pulled the injector wires off 1 and 2 (i have a kit to clean injectors and also spare injectors, the injectors are working and fuel pressure was good. I then put everything back together ...well cyl 1 still at 150, cly 5 has gone up to around 700, 3 and 7 still aroung 350 but now 2, 4, 6 and 8 are all at around 150... i'm thinking optispark, i have a spare but when i try to test it only flashed once then dead.... didn't try all ports. I hate to have to take off the optispark again and get another just to get junk (lifetime warranty form autozone). is there anyone who knows of a reliable optispark? thanks
craby Mar 10, 2026 04:54 PM
did you replace the opti wire harness? triple check to make sure plug wires are to correct place. could be pcm or opti issues.
powellwfp@yahoo.com Mar 11, 2026 11:53 AM
yeah new opti came with harness. sure that plug wires are good, as my first test with the temp showed around 350 degrees on all cyl except #1 , crazy thing after making sure everything was tight but second test I has dead holes in # 1 & 2. next time all holes on passengers side dead.... so yeah thinking opti spark or pcm/ecu
craby Mar 11, 2026 06:21 PM
I dont think it would be ignition control module, I believe they let it run or not. at least that's what I have seen.
powellwfp@yahoo.com Mar 12, 2026 02:37 AM
yeah I also think its not the ecu, Must be the opti, got another one today (warranty) gonna "bench" test before installing.
This is the way I test these things. I have an extra module harness and connect to the ecu and use extra ignition wire to coil and use a drill to spin the opti to check for spark at each port.
If anyone has other way to test like the input.
craby Mar 13, 2026 02:58 AM
look at 28 here see if it helps any. shbox is good 4th Gen LT1 F-Body Tech Aids
