94 z28 Governor
The only speed limiter came on cars that were not equipped with Z rated tires, and the limiter was set at 115 MPH. If yor car can't get over 130 most likely the engine id misfiring under load. Bad plugs, bad plug wires, low fuel pressure under heavy load, sick engine, non stock final drive gears.
